UI feature request: show note text area for weblocs
Hello,
I have the habit of adding notes to weblocs I store in EF to help search for them. Unfortunately it means opening a floating palette to do so. As there is not much to display about weblocs (beside title and URL), it would be great if the note field was also displayed and editable.
Alan
There have been some other threads that discussed making the notes viewable and editable in the main browser window. Although you’re right that bookmark records uniquely have lots of extra space for doing this, at this point I think it makes sense to come up with a design that would work for all record types.
I’ve seen the other threads, and my suggestion was targeted for weblocs as it seems to be simpler. But I would be very glad for a generic solution.
