Just a note that the label column is not able to resize, thus the Purple is truncated.
Currently, Label and some other columns have a fixed maximum size in order to avoid stealing space from other columns as you resize the window. Unfortunately, this means that if you increase the font size (or choose a wider font) they may get truncated. With SpamSieve 3, I built a new system where table columns can auto-set their width based on the current font and the possible cell values, and Iām planning to bring this to EagleFiler in a future version.
