Uncertain Junk category in Entourage doesn't exist
Hi,
I’m trying SpamSieve for the first time. I’m an Entourage 2004 user with an Exchange account.
I installed and set up SpamSieve as explained in the manual, and it is working fine, except for one thing :
I want to have Entourage put the Junk and Uncertain Junk messages in separate folders, so I created the third rule called “SpamSieve - Move Uncertain Messages”.
Unfortunately, there is no “Uncertain Junk” in the category list.
Should I create it myself ?
Thank you.
You can create it yourself, or else SpamSieve will create it the first time it marks an incoming message as uncertain.
