Uninstall SpamSieve Problem
After uninstalling SpamSieve from my Mac, now all my mail goes to the Spam folder instead of the Inbox.
Anyone know how to resolve this?
Thanks!!
~Paul
Figured it Out
SpamSieve failed to remove a rule created during install.
FYI: The program worked ok, I’d like to evaluate a few others before purchasing.
Thanks!
Did you use the Uninstall Apple Mail Plug-In… command? That should offer to remove any SpamSieve rules that it finds. If you used that command and it didn’t prompt you, what was your rule’s name?
Sure did.
What was the rule that didn’t get removed during uninstall process?
Because I am having the same problem after following the same uninstall process, and can’t seem to find a related rule.
The rule should be called “SpamSieve”, but you can look in Mail’s preferences for any rule that moves messages to the Spam mailbox.
