I would like to click on a bookmark or file in EagleFiler and open an external file outside Eaglefiler. A pdf, a spredsheet, etc
How do I do this?
thank you
I think what you’re looking for is the Record ‣ Open With [App Name] command. You can also double-click the record.
I want to be able to open a file on my hard disk from Eaglefiler. I want to save the location of the file in Eaglefiler
Files managed by EagleFiler normally need to be moved or copied into the folder for your EagleFiler library. However, it is possible to import an alias file, and then when you open the record in EagleFiler it will resolve the alias and open the original (external) file.
