I previously set up Apple Mail to use the Junk mailbox according to directions on your site or within the forums I can no longer find. Due to problems with Mail, I recently had to disable SpamSieve for a while, but I’ve finally re-enabled it (I’m using Mavericks and SS 2.9.13). Is it still possible to simple use the Junk mailbox and, if so, would you please link to the instructions for that?
thanks. had a little problem understanding that allowing the result of the Junk advanced settings still needed to move the result (no emails) to Junk.
So far it seems to work. I also presume that the “built-in Junk filter” rule in the Rules should be disabled (?)
