Using EagleFiler as a Change Control System
Clay Moore uses an RTF file as stationery for a change control form:
Change Control in Project Management is one of those problems you have to solve. Using cards, paper, and folders is just messy, but it can work. EagleFiler can work with this mess and make it a paperless or less paper solution.
