View Options
Hi. I just got EagleFiler and have question on how to look at the document chosen. Is there any way to look at the document on the right side of the the window as opposed to only the bottom. When it’s a vertical page (as most are), it’s easier to see the whole page on the right side without having to scroll. Thanks a lot for your help.
Rick
Currently, you can’t move the record viewer to the right of the records list. But you can drag the divider to the top of the window so that the document utilizes its full height.
Thanks, Michael, for your prompt reply. Is this something you will incorporate in a future version?
Richard
Yes, in a future version I’m planning to make the window layout configurable, like in Mail.
