Hi,
Is there any way to toggle between webarchive and webloc types on the fly when we import an URL?
Is there any way to easily refresh a web archive in EF?
Thanks.
Hi,
Thanks.
Aside from changing the preferences, you can do this via bookmarklets or AppleScript.
You can do this via the Reload Web Pages script.
Thanks for the quick reply.
Feature request: it would be very nice to have a modifier key for the URL drag, and a contextual menu item for the web archive reload.
Regards.
Noted, thanks. Right now you can hold down the Option key when importing to set some options (although the format isn’t currently one of those options).
