what's up
Since the latest update whenever I open a text file to edit a document Eaglefiler opens !!!
I’m guessing this is something local to your Mac because EagleFiler doesn’t tell the OS that it wants to open your text files. You can change the preferred application by using the Finder’s Get Info command or by selecting the file in EagleFiler and choosing another application using Always Open With.
thanks …
Thanks , Michael, that fixed my problem.
