whitelist and corpus questions
Am I correct to infer that Spamsieve scores each msg that matches a whitelist rule as a “1”?
Does Spamsieve re-balance the corpus using new msgs that match the whitelist? Or does it only update the corpus with msgs not matching the whitelist but which it considers “good”?
I started using Spamsieve a week ago with 1000 msgs (65% spam). The statistics are now:
Filtered Mail
154 Good Messages
5,487 Spam Messages (97%)
764 Spam Messages Per Day
SpamSieve Accuracy
5 False Positives
16 False Negatives (76%)
99.6% Correct
Corpus
401 Good Messages
936 Spam Messages (70%)
56,388 Total Words
Rules
2,727 Blocklist Rules
866 Whitelist Rules
Showing Statistics Since
2/20/07 4:41 PM
Is 70% still within the balanced range or is this an indication of a problem?
Yes.
Yes, depending on the current corpus composition and on whether it thinks the messages are interesting.
70% is fine. If you simply correct any mistakes that it makes, SpamSieve will automatically keep the corpus relatively balanced.
