Hello sir, I am getting this issue recently, actually my version might be older slight as I am using my system after a long time, I set up my airpods but the menu icon appears as the C-Command wand logo. In preferences I have tried clicking the icon with no luck. I use TF 2.4.9 (39)
Sorry, that’s a known issue on macOS 10.11. If you contact me via e-mail I can send you a beta version that fixes it.
Oh I didn’t check that, thanks btw, its fine again.
This is fixed in ToothFairy 2.5.
Yeah thanks sir, 2.5 is wonderful version.
