Zoom to fit pdfs
Did something happen to “zoom to fit” with regards to pdf files?
For some reason I can’t zoom to fit pdfs, and I usually have that as my default. Is there an issue with this latest update, or can someone point me the way? Thanks much!
It seems fine to me. What happens when you choose “View > Zooming > Zoom to Fit” or Control-click and choose “Automatically Resize”?
doh.
I think I probably goofed something up, I can’t check on it until Monday, so if I don’t reply back, I solved it. THANKS MICHAEL!
