First off, great program!
These suggestions stem mostly from copying text from Web pages and needing to document where it comes from. I currently use the Drop Pad for that.
- An alternative option for the Drop Pad so that I don’t have to dig it out from under other windows. Could it have a place on the Dock? Menu Bar?
- Another option for this would be for Command/Shift/5 to capture source information. Then, I would not need the Drop Pad.
There may be alternatives already to the suggestions above. I would love to hear if someone else has this figured out.
My other request is one you are working on - real time tags. I appreciate you making that one top on your list. Seems a lot of people are interested in it.
Wayne
PS What about a system-wide key to bring the Drop Pad forward - is there a way to accomplish this with another automator/macro-type tool?
