Hi,
I’m not sure if its the done thing to post scripts but here goes. I have modified one of the stock scripts so that it adds a date time stamp as a prefix to the original file name and also swaps any space characters for dashes.
I rename files because in the past I have found that meta data such as creation date can get modified and space characters cause problems when files are placed on servers or even referred to in shell scripts.
-- Script that modifies the filenames of records managed by EagleFiler
-- The files creation date is used to add a date prefix and all space characters are replaced with dashes
-- V1 dated 19th November 2020 by Skids who borrowed other peoples code and made a few small changes
-- Test before use and USE at OWN risk
-- e.g. File : "My great File Name.pdf" is renamed "2020-11-19-115723-My-great-File-Name.pdf"
tell application "EagleFiler"
set _records to selected records of browser window 1
set _dateString to my stringFromDate(_record's creation date)
set tOriginalName to _record's basename
set tCleanName to my ReplaceSpaces(tOriginalName)
set _record's basename to _dateString & tCleanName
end repeat
end tell
on stringFromDate(_date)
-- yyyy-mm-dd-hhmmss-
set _string to ""
set _string to _string & my stringFromNumber(_date's year, 4) & "-"
set _string to _string & my stringFromNumber(_date's month as integer, 2) & "-"
set _string to _string & my stringFromNumber(_date's day, 2) & "-"
set _string to _string & my stringFromNumber(_date's hours, 2)
set _string to _string & my stringFromNumber(_date's minutes, 2)
set _string to _string & my stringFromNumber(_date's seconds, 2) & "-"
return _string
end stringFromDate
on stringFromNumber(_number, _digitsToPad)
return text -_digitsToPad through -1 of ("0000" & _number)
end stringFromNumber
on ReplaceSpaces(inputString)
-- store original applescript settings just in case
set TID to AppleScript's text item delimiters
set AppleScript's text item delimiters to " " -- space character
set pieces to text items of inputString -- break string apart at space characters
set AppleScript's text item delimiters to "-" -- spaces replaced with dash character
set inputString to pieces as text -- put string back together using dash
--reset original as settings
set AppleScript's text item delimiters to TID
return inputString
end ReplaceSpaces
