Can't stop EagleFiler attempting to open a Library
Hi, I just updated to the MacOS 26 Public Beta and now Eaglefiler wont open my main Library File. So I enrolled in the eagleFiler Public Beta but i cant stop the app from attempting to load the library and getting stuck at that point…which of course wont allow me to update to the Eaglefiler beta. Is their a key command or something that can stop it from trying to open the library on launching the app? Thanks in advance.
Yes, you can hold down Shift.
Perfect! thankyou. Beta version opens my library perfectly.
