Here’s a new beta version of EagleFiler. The changes are:
  • Improved importing from Evernote. EagleFiler is better at detecting when a note contains only a single attached file, so that it can be imported directly rather than embedded in a rich text file, and in such cases EagleFiler now preserves any custom author information that you’d set in Evernote.
  • Improved the fallback source URL generation for e-mail messages.
  • Fixed a regression where the From wasn’t set when capturing from Twitter.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
