EagleFiler 1.9.16
Version 1.9.16 of EagleFiler is now available.
  • Improved the formatting of community notes and quote tweets when importing from X/Twitter.
  • Worked around a bug in macOS 15 where sometimes the system help viewer wouldn’t open to the right help page. EagleFiler will instead open help files in the user’s Web browser.
  • Fixed a bug where Merge Mailboxes/Message Files might fail if the files were stored in iCloud Drive but not downloaded to the Mac.
  • Fixed a bug where EagleFiler might improperly recognize certain folders as mailboxes when importing.
  • EagleFiler no longer triggers the “find devices on local networks” prompt on macOS 15.
  • Made some changes to track down an issue where files stored in OneDrive on macOS 15 might be incorrectly reported as missing.
  • Removed support for Growl, as all supported macOS versions now have Notification Center built-in.
  • Removed various unused code.
  • Fixed the broken help button in the Settings window.
  • The diagnostic report now includes information about the app’s logs, the crash logs folder, and components that could cause AppleScript errors.
  • EagleFiler is now built with Xcode 16 and the macOS 15 SDK.
Is this still intel, or Universal?
It’s Intel. More info here.
