EagleFiler 1.9.18b3 Public Beta
Here’s a new beta version of EagleFiler. The changes are:
  • Restored the ability to select the system font size from the Fonts panel. This should now work on macOS Tahoe 26 Developer Beta 6 and later, but it will still crash on earlier beta versions.
  • Fixed a regression where minimizing a window could change the current library if all the other libraries were already minimized.
  • The Merge Message Files command no longer marks the new mailbox record as unread if all the messages were already read.
  • Text fields now disallow macOS 26’s Security Code AutoFill since it’s not relevant.
  • Added the Prefix Creation Date to Filename script.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 2.
