EagleFiler 1.9.18b2 Public Beta
Here’s a new beta version of EagleFiler. The changes are:
  • Made further changes to prevent crashes due to font panel bugs in the macOS Tahoe 26 beta.
  • If you assign a folder the ef_noindex tag, none of its files or subfolders will be indexed, either. (Previously, only individual files could excluded from indexing.)
  • Added the Importing Mail From MailMaven section of the manual.
  • Updated the following sections of the manual:
  • Adjusted the behavior of the Drop Pad so that can it still migrate to the proper space but hopefully doesn’t show up on the wrong display of a multi-display setup.
  • Updated EagleFiler’s frameworks for Xcode 26 and macOS Tahoe 26.
If you have not installed a beta version of EagleFiler before, first click here to enter the beta key. Thereafter, you can just launch EagleFiler or choose Software Update from the EagleFiler menu to auto-install the beta. EagleFiler will also notify you about future betas automatically. You can click here to stop receiving in-app notifications of beta versions.
Previously: Beta 1.
Hello,
When I try to click on update to “EagleFiler 1.9.18b2 Public Beta” I can’t do it because it stays trying to connect with my library. You could share the direct dmg or something that solves the power to update. I already have macOS 26 public beta 2 installed.
Thx.
If you hold down the Shift key when launching EagleFiler, it won’t try to re-open your library, and then you should be able to do the update.
