simple as that really its ticked but nothing happens.
also the shell script does work either, I have this pasted in it “#!/bin/sh
SwitchAudioSource -t input -s ‘MacBook Air Microphone’”
and nothing changes.
Sounds like a macOS issue. Are you able to switch the sound input manually (in System Preferences) or using SwitchAudioSource in Terminal?
Which device’s microphone is it trying to use?
I installed ToothFairy for the first time today and I discovered that I had to put export PATH=/usr/local/bin:$PATH one line before the SwitchAudioSource command.
i.e.
#!/bin/sh
A post was split to a new topic: “Improve sound quality” feature not working after putting AirPods Max aside
