Spam not going into spam folder. When I mark messages as spam, they go to the folder, but nothing goes into the spam folder as email comes in to mac mail. The plug in is checked and spam sieve shows up under my messages tab.
I should add that this is on a new M1 Mac Book Air. It hasn’t worked since I started using this computer.
Please check your Apple Mail setup, in particular the SpamSieve rule.
Thanks! This did the trick. Is there any way to get spam to move into spam folder rather than junk folder?
I recommend using the Junk mailbox, but you can change it to Spam if you want.
Ok. Thanks!
2 posts were split to a new topic: Incompatible Plug-in with Apple Mail on Monterey
