  • Preliminary testing shows that SpamSieve is compatible with macOS 15 Sequoia Developer Beta 1. Please let us know if you find any issues.
  • Worked around an Xcode bug that could cause a crash at launch on older versions of macOS when SpamSieve checked whether the Mac was connected to the Internet. If you had already installed SpamSieve 3.0.5b1 and disabled this feature to prevent the crashes, you can re-enable it after updating to b2 by clicking this link.
  • The mailbox outline now recognizes lowercase spam and junk mailboxes.
  • Improved the error reporting to track down an Apple Mail AppleScript issue when finding new messages to filter.
  • Updated for Swift 6.
Previously: Beta 1.
