- Made various updates for Xcode 16 and macOS 15.
- Improved the error reporting when a database can’t be accessed because the disk is full.
- Fixed a bug where the notification score slider was too narrow on macOS 10.13.
- Modernized text fields to use shaded bezels instead of solid lines.
- Secondary label text throughout the user interface now uses the modern gray coloring.
Previously: Beta 2.
