SpamSieve 3.3.2b1 Public Beta
  • Help links once again open in the system help viewer on recent versions of macOS.
  • Checkbox values such as Locked and Enabled are now included when copying from rules windows.
  • Tried to work around a seeming Xcode change that caused crashes when reading the corpus database.
  • Fixed a crash that could occur after software update.
