Toothfairy doesn't work macOS Big Sur
Hi All,
I had purchased the app a long time ago on Catalina and the app was working flawlessly. Ever since my update to Big Sur the app no longer opens. I just get the error message saying its damaged and to delete it and reinstall it. I’ve reinstalled it maybe 10 times.
Thanks for any help in advance.
This may be caused by a networking error. Could you send in an error report (right after you try launching the app) so that I can investigate further?
I think ToothFairy 2.7.1 works around the macOS issue that could cause this error.
