SpamSieve 3.2b2 Public Beta
  • The Corpus and Log windows now show the message’s From address in addition to the sender’s name. This should make it easier to tell at a glance which messages are spam.
  • SpamSieve reports more error information when there’s a problem opening a database file.
  • Fixed a bug where a rule matching the sender’s name might not match a message if the name used an Asian character that had a different Unicode width.
  • Work around a bug in Xcode 26 that could cause a crash at launch on macOS 10.13.
  • Worked around some Swift Concurrency changes in Xcode 26.
  • Text fields now disallow macOS 26’s Security Code AutoFill since it’s not relevant.
  • Removed a workaround for an Xcode 15 bug. Please let us know if this brings back crashes on older versions of macOS.
  • Improved the following section of the manual:
Previously: Beta 1.
I’ve pulled the beta because it looks like Apple did not actually fix this bug, so it’s causing crashes at launch for some configurations.
Can you make the maximum width of the From column wider and add a help tag to show the whole address? Since it now contains email addresses as well as names it can end up quite long.
Here’s a (legitimate!) example from my own email.
I’ve added this in beta 6.
